[Help] Monitor won't turn back on after sleep mode?
ad88
45
I just recently put my new rig together, so the Windows 7 Ultimate 64bit install is fresh, and all the drivers are the latest available. I have updated my mobo's bios to the latest version through Asus' "AI Suite II" which makes things very simple. I want my PC to be able to go into sleep mode but I don't want to have to force shutdown every time it goes into sleep mode after a time span. For some reason if I wake my PC after its been in sleep mode for a short period everything turns back on just fine... I know there might be a solution through the configuration panel - power management, but i'm unsure what I need to do if I want to keep sleep mode possible without the issue.
I am having the same problem with my system, I have a P8z68-V LE with an 2600k I7 3.4 ghz. I used the suite to overclock my CPU to 4.4ghz.
I turned the pll overvoltage off and my computer now wakes from sleep mode. Thanks for the fix. Did you notice any kind of CPU temperature change after you turned your overvoltage off?
I can't say really. Unless your overclocking I don't think it should make a difference.
