Help my main system crashed!
ragsters
792
Yesterday I was online when my computer froze. The mouse courser was stuck and there was nothing I could do. I pushed the reset button on my computer and it never booted up or even post. I didn't even get a beep code. I tried reseting the cmos and restarting but still no post. I removed everything but the cpu 1 video card and 1 stick of ram and tried booting up but still nothing. If you look at my profile you would see that I have the Asus Rampage Formula motherboard. On the included lcd poster when I boot up my computer it gets stuck on DET RAM. Please give me some advice on what to do.
Try this:
Pull everything except the CPU and HSF. Boot. You should hear a series of long single beeps indicating memory problems. Silence here indicates, in probable order, a bad PSU, motherboard, or CPU - or a bad installation where something is shorting and shutting down the PSU.
To eliminate the possiblility of a bad installation where something is shorting and shutting down the PSU, you will need to pull the motherboard out of the case and reassemble the components on an insulated surface. This is called "breadboarding" - from the 1920's homebrew radio days. I always breadboard a new or recycled build. It lets me test components before I go through the trouble of installing them in a case.
Here's a somewhat extreme example of breadboarding:
http://www.tomshardware.co.uk/forum/page-262730_13_0.html
You can momentarily short together the two motherboard pins that the case power switch go to.
If you get the long beeps, add a stick of RAM. Boot. The beep pattern should change to one long and two or three short beeps. Silence indicates that the RAM is shorting out the PSU (very rare). Long single beeps indicates that the BIOS does not recognize the presence of the RAM.
If you get the one long and two or three short beeps, test the rest of the RAM. If good, install the video card and any needed power cables and plug in the monitor. If the video card is good, the system should successfully POST (one short beep, usually) and you will see the boot screen and messages.
Note - an inadequate PSU will cause a failure here or any step later.
Note - you do not need drives or a keyboard to successfully POST (generally a single short beep).
If you successfully POST, start plugging in the rest of the components, one at a time.
