Help, my motherboard wont show any post(black screen all the way cpu fan does turn on)
yaniv382
21
Hi, a friend gave me a motherboard which looks in a good shape the capacitors and everything look ok but when i try to boot it i dont get any post and i know for sure that my ram gpu and cpu are working and also the chip support my cpu
my question is, is there a possiblity that the cmos jumpers on board could affect booting if they are set wrong?
also how do i know on which pin they should sit when i dont want to reset cmos and also could the mobo turn on if i just take the jumpers off?. thanks in advanced :)
specs
CPU: core 2 duo e8400
GPU: gt610
RAM: DDR2 8gig 800hz
MotherBoard: Gigabyte GA-G41M
PSU: 500W
O.K.
i mean my real question is about the jumpers
