HELP need a video card
russellrc
83
http://pcpartpicker.com/p/21NzT
this is my build. All bought but video card. ordered 1 but order was canceled by them Sapphire Radeon HD 7950 3GB DDR5 HDMI / DVI-I / Dual Mini DP with Boost PCI-Express Graphics Card 11196-16-20G $259. do not want to spend more than around 250.00-300.00 all around card. do not use for 1 thing. fast is liked. nothing else can change but opinions welcome. BUT need video card.and want one i can expand with help please
The R9 280x is at the very top of your budget and is a little more expensive than the 7950 but provides lots of performance. If your planning on mainly using your computer for gaming i would definitely choose the 280x. The 760 is an excellent cheaper option if you want to go that route.
