[SOLVED] Help Needed, System Crashing Repeatedly
lunarfreakz
74
So I have been getting a lot of BSOD recently (in the past month) and the stop codes I have been receiving are:
WHEA_UNCORRECTABLE_ERROR
SYSTEM_SERVICE_EXCEPTION
IRQL_NOT_LESS_OR_EQUAL
UNEXPECTED_KERNEL_MODE_TRAP
DRIVER_OVERRAN_STACK_BUFFER
DRIVER_IRQL_NOT_LESS_OR_EQUAL
KMODE_EXCEPTION_NOT_HANDLED
SYSTEM_SERVICE_EXCEPTION (What failed: nvlddmkm.sys)
CRITICAL PROCESS DIED
- after I received this Automatic Repair failed to repair my PC and mentioned at the bottom of the Blue Screen "Log file: C:\Windows\System32\Logfiles\Srt\SrtTrail.txt"
I did managed to reinstall Windows 10 however I received the BSOD with the stop code: SYSTEM_SERVICE_EXCEPTION
(If it helps to give the order in which I have been receiving this, then I can do that as I took pictures almost every time I got the BSOD)
(These are already kind of in order of how I have been getting them but sometimes some of the stop codes popped up afterwards again so that is what I mean by order of occurrences; including the repeated ones)
When does this issue occur:
All of these stop codes occured whenever I would try to launch into a game in Fortnite, launch Fortnite or when I would leave a game of Fortnite to go back to the lobby. Therefore, this would happen whenever I was gaming.
I reassembled my PC and reinstalled Windows 10 but then, as mentioned above, after playing Fortnite for a bit (without the GPU or HDD connected) on my CPU graphics, the PC crashed and gave me the BSOD with the above mentioned stop code (SSE one).
Unfortunately whilst these BSOD were happening, I did try to dust off the inside of my PC with a vacuum cleaner (I did not touch any components) but not much of the dust came off. Then when I was cleaning the rest of my room I accidentally tipped my PC off my desk and it stopped halfway to the ground as it banged a bit against my other chair beside my desk and stayed there slanted. I checked where the chair hit the computer and it was right at the spot where there was no component on the other side of the side panel with the dent. The BSOD continued after this, not sure if this was in any way a cause to this problem.
System Spec:
CPU:
Intel - Core i7-8700 3.2GHz 6-Core Processor
Motherboard: Gigabyte H310M H
RAM: Crucial DDR4 Ballistix Sport LT 2x8GB 2666
GPU: VGA Gigabyte GeForce GTX 1080 Windforce OC
SSD: Samsung - 860 EVO-Series 500GB 2.5" Solid State Drive
HDD: Seagate BarraCuda, 2 TB Hard Drive
Case: Corsair - 200R ATX Mid Tower Case
PSU: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply
Please let me know if you have any solutions or ideas about this! Thank you
2a [2 of the 5 warning signed drivers had this])
This device cannot find enough free resources that it can use. (Code 12)
If you want to use this device, you will need to disable one of the other devices on this system.
https://windowsreport.com/device-cant-find-enough-free-resources-error-code-12/
2b [2 of the 5 warning signed drivers had this])
This device cannot start. (Code 10)
The device is not in a valid state to perform this request.
https://www.lifewire.com/how-to-fix-code-10-errors-2623181
Have you done the things I did? Because then you might need to buy a cooler, but yeah keep following this post and I'll update the thread after I upgrade my CPU cooler :)
I am far from understanding this stuff at the level some of you do. So no, i have not tried exactly the things you have tried. Im having trouble even getting people to recommend things to try. I am new to this pc world, and learning a lot, but limited on my knowledge of software and drivers and what works with what etc. All I did was install 1080ti in existing build and now PC crashes in certain games.
Well PC's are about balance, so depends on your whole build.
I would suggest you make a new thread and put your PC specs and the issue that you have. Be as detailed as possible and wait for someone to help you out. Your problem seems to be different than mine as it might have to do with components of PC settings rather than overheating like is a possible reason for my issue. Send me the name of your new thread in private message, I'll be interested to follow what ideas people have to do with your problem!
But of course you are very welcome to continue following this thread!
