I'm currently using a four year old P4 2Ghz computer with a Geforce 3. Needless to say, I need to upgrade. I'm trying to build a computer that will be used primarily for gaming. I had been doing quite a bit of research towards this, but had been focusing on retailers, such as dell, alienware, abs, etc, but not so much on specific hardware. I have about $2000 - 2500 to spend and from what limited knowledge I have, I'd like to get the intel core 2 duo e6700, as I think its a good value for its performance, and the geforce 7950, so I can use its high definition out. I'm willing to use different hardware, though, if you can provide compelling arguments for not using the e6700 or the 7950. Also, all I'm looking for in a sound card(or integrated sound) is 5.1 capabilities. So, I would greatly appreciate any advice with regards to good gaming builds that I can afford.
Thanks
Thanks
