Hi Normally i like to make an informed decision on my own however i'm really stumped at the moment and would appreciate some opinions on the laptops and the companies .
So the laptop would be for mostly programming / web development running a start up (software is not operating system dependent). As well as some gaming as this would replace my high end gaming desktop (not getting rid of it just wont use it as much). [Gaming is not the most important factor here].
Laptop 1: Pc Specialist 13 Inch
1) QHD 3200x1800 screen
2) i7 4710MQ
3) 860m
4) 500gb samsung evo
+ Well priced at about £850
+ relatively light 2kg
+ Great screen
- People say it gets really hot sometimes up to 90+ degrees
- smallish screen
- 32mm thick which is quite large
- Battery not great at 4ish hours
https://www.pcspecialist.co.uk/notebooks/optimusV-13/
Laptop 2: Cyber power Edge X6 15 in
1) 1920 x 1080 screen
2) i7 4710MQ
3) 870m
+ Screen size
+ better gfx
+ thinner and same weight
+ space for second HHD
- screen resolution not as good as others
- price £1200
- Battery not great at 3 -4 hours
https://www.cyberpowersystem.co.uk/system/ZEUSBOOK_EDGE_X6-100
Laptop 3: Apple Macbook Pro 13 Inch
Base model will be able to get it for about £850
+ screen quality
+ i like the op system more
- price for parts
Any advise or alternatives would be great.
2) i7 4710MQ
3) 860m
+ Great screen
- smallish screen
2) i7 4710MQ
3) 870m
+ Screen size
+ better gfx
- price £1200
+ screen quality
- price for parts
