Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
thank you all
since i didnt get the 2200 xp to run on this board i got me aa other board
from a friend.
works with xp up to 3200 with no prob (elitegroup k7s5a)
thanks for your help
"Paul" <nospam@needed.com> schrieb im Newsbeitrag
news:nospam-2202050149090001@192.168.1.177...
> In article <%VpSd.62259$2e4.18828@news.chello.at>, "Thomas Goetz"
> <elonini@fantasymail.de> wrote:
>> hello
>> can anyone help me out please
>> got an asus a7v133 ver. 1.05(no dot) and amd site says that it should
>> work
>> with amd XP2200+ and manual jumper setting
>> tryed some things i found at several websites but the 2200 wont boot
>> does anyone have exact settings for that board + cpu please
>> thank you
> And what does this show you ?
http://www.asus.com.tw/support/cpusupport/cpusupport.aspx
> It shows Palomino Model 6 only works if using a "1.05." board.
> I interpret that to mean, the "1.05." board is equipped with
> the L-C-L filter network which is needed by the PLL in the
> processor. Without that filter, some processors may work and
> some may not. The filter network is needed by later processors,
> and the requirement was not met until 1.05. .
> Model 8
> CPU ID 0681 1800 (2200+) OPGA 133 256 13.5x 1.60V 85oC 57.0W
> CPU ID 0680 1800 (2200+) OPGA 133 256 13.5x 1.65V 85oC 61.7W
> I take it you have the frequency set to 133Mhz ?
> Is the voltage set properly for your processor ?
> Are you trying jumper mode or jumperfree ?
> (If it was my board, I would try the jumper mode.)
> Due to the way that power planes are laid out underneath large
> chips, it is virtually impossible to retrofit a filter network
> for a PLL. So, I hope the processor just works, with the noise
> level on VCCA pins as it stands now. For boards before 1.05.
> it is not guaranteed to work.
> See the section "Will a AthlonXP run in a A7V / A7V133 /A7V266
> etc. that does not officially support it?" on this page:
http://www.a7vtroubleshooting.com/info/cpu/index.htm
> You might also search
http://forum.a7vtroubleshooting.com .
> Set the "max age" to a number much larger than the default
> 7 days. I use 1000 days, to search close to three years of postings.
http://www.a7vtroubleshooting.com/forum/cgi-bin/yabb/YaBB.pl?board=;action=search
http://www.a7vtroubleshooting.com/forum/cgi-bin/yabb/YaBB.pl?board=a7v;action=display;num=1103991589;start=0
> Paul
