Hello, I'll start by explaining what I need to do with my pc. I play heaps of poker and use various software in the back ground. I need to run 2 monitors for a start. I multi table and use table nynja to help me with that which is running in the background. I also use holdem manager which uses postgreSQL data base, also running in background. I need to have all this running as well as a internet page open at the same time. My computer is a dinosaur and can't handle any of this. I need to sometimes import a lot of data and in the future would like to be able to upgrade to a SSD hard drive but can't afford it at present, so components need to be compatible please. I've heard someone does this and uses a intel i7 cpu and only uses 10% of it so I would prefer something cheaper if this is overkill. Thank you in advance.
