Help, please. Explorer.exe is causing huge problems.
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
At least twice per day Explorer.exe hogs the CPU to 99%.
I have no idea why. I can only stop it by rebooting.
It has started doing so only the last two weeks or so.
I use Windows XP Pro, Norton Security, Stopzilla, Counterspy, Microsoft
anti spyware, Norton Ghost, Retrospect Express for my backup drive.
I have a Pentium 4 2.25 Ghz, 1.5 Gb memory, Nvidia graphic card.
I have searched Microsoft Knowledge Base as well as Google groups and
have found no answers.
I could really use some help on this, please.
Thanks,
Richard
> Thanks,
> Richard
Are you doing all malware scans in safe mode?
THE PARASITE FIGHT
Finding, Removing & Protecting Yourself From Scumware
http://aumha.org/a/parasite.htm
Richard Harper’s Guide to Cleaning Pests
http://rgharper.mvps.org/cleanit.htm
Rock
MS MVP Windows - Shell/User
Here is something that may help.. but you have to spend some time
investigating.
Download the extended task manager, http://www.warecase.com/products.asp
run it and click on the EXPLORER. EXE and look at the loaded modules (dll's)
one by one.. see if you see anything suspicious loading with EXPLORER.
Thats how I found out some of the problems I had
Kenny. www.computerboom.net
"arjay" <vidman99-gg@yahoo.com> wrote in message
news:1125798471.357958.58510@o13g2000cwo.googlegroups.com...
> Thanks,
> Richard
> investigating.
> > Thanks,
> > Richard
I Have had the same problem for six months and have run Norton, MS antispam
and every know anti-spyware and AV program and none have helped.
Someone please help. I now run by closing Windows Esplorer a startup and
have to run everything from task manager.
Dell 2400 - Windows XP home with all upgrades.
> investigating.
> > Thanks,
> > Richard
