Help Please! Updated Graphic Problem
Stardust342
258
27
Well you said you removed the driver in Add/remove programs, and that didn't work. We could try removing it in Device manager, but if that doesn't work, we'll have to factory reset your computer.
Pro4Ever
31
i didnt remove the driver in add/remove programs, i tried it just now and it doesnt work, also i saw a some of intel programs in processors and system devices
Stardust342
258
27
Have you tried to enter BIOS yet? When you turn on your computer, press del or f2 a bunch and you should enter it. It should also tell you what key to press on the first loading screen.
Stardust342
258
27
Your laptop may have the feature built in, by pressing a certain button at start up, or you'll have to download an ISO of you exact version of Windows, burn it to a CD or USB drive, and then follow these instructions if you have never installed Windows before.
