HELP!!!!! PLEASEEEE!
Bozzvegas
42
Hi guys a couple of quick questions!! 😀
I'm a novice overclocker and would love some advice on what your suggestions of my overclock be! I"ll settle for 333 FSB with my ram,what do you think we be a good stable O/C on my cpu!!
What Stability programs do you Recommend??
Bios suggested settings??
Temperature programs/ Recommended idle and load temps??
ANY HELP WOULD BE GREAT!! THANKS FOR YOUR TIME! 😀
E6600
nvidia 680 i Mobo
2 gigs @ 667
2 7950 gt OC 512mb in sli
750 thermaltake PSU @ 40a
500 Gb sata II 16 MB Cache
X-fi gamer sound card
etc
First off, don't let the vCore at auto, normally something around 1.4 should do great and the cooler should handle it fine.
run two instance of Prime95, you need to make two seperate folder with 2 "install". And set processor affinity accordingly(in the program).
Use core temp for monitoring. under 40c idle and under 60-65 with dual prime should be what you aim for 24/7. Dual prime should be at least 6h for 'ultimate' stability, I found that 2h runs are usually stable enough for 24/7 but still.
Bios I don't know latest should help! I also suggest staying in linked mode!
Good luck!
