I have an old Western Digital Caviar SE drive - WD1200JB. It stopped working years ago but I've held onto it hoping I could one day recover the data I need on it.
The original OS was Windows XP.
There are no clicking sounds.
Drive powers up and spins without any odd sounds.
I bought this tool and it works great for hooking up older drives: http://www.amazon.com/Vantec-CB-ISATAU2-Supports-2-5-Inch-5-25-Inch/dp/B000J01I1G/ref=sr_1_4?ie=UTF8&qid=1413917713&sr=8-4&keywords=hard+drive+usb
So I hooked up my old WD1200JB hard drive. It powers up just fine. No clicking sounds. It appears to be spinning just fine.
On my Windows 8 computer, the drive does not show up under My Computer. However, I went into disk management and the drive is listed. Disk Management states the drive is not initialized and the capacity is listed as unknown. I checked properties and it states: This device is working properly.
So then I downloaded Data Lifeguard Diagnostics for WIndows here:
http://support.wdc.com/product/download.asp?groupid=612&sid=3&lang=en
I ran the first two tests in the diagnostic program from Western Digital and the drive passed both tests.
Test Option: EXTENDED TEST
Model Number: WDC WD1200JB-00GVC0
Unit Serial Number: WD-WCALA2181147
Firmware Number: 08.02D08
Capacity: 0.00 GB
SMART Status: Not Available
Test Result: PASS
Test Time: 11:42:37, October 21, 2014
Test Option: QUICK TEST
Capacity: 0.00 GB
Test Result: PASS
Test Time: 11:43:07, October 21, 2014
There is an option on the diagnostic program to perform a 'write zeroes' to the drive. Obviously if I do that, there is a really strong chance I will not be able to recover data. Although I've seen some posts claiming success of recovery or partial recovery after writing zeroes to the drive.
Then I downloaded the USBView Tool and this is what it gave me. Not sure if it's only seeing the ATA/ATAPI bridge and not really seeing the drive?
---===>Device Information<===---
English product name: "USB to ATA/ATAPI bridge"
ConnectionStatus:
Current Config Value: 0x01 -> Device Bus Speed: High
Device Address: 0x08
Open Pipes: 2
===>Endpoint Descriptor<===
bLength: 0x07
bDescriptorType: 0x05
bEndpointAddress: 0x81 -> Direction: IN - EndpointID: 1
bmAttributes: 0x02 -> Bulk Transfer Type
wMaxPacketSize: 0x0200 = 0x200 max bytes
bInterval: 0x00
bLength: 0x07
bEndpointAddress: 0x02 -> Direction: OUT - EndpointID: 2
bInterval: 0x00
===>Device Descriptor<===
bLength: 0x12
bDescriptorType: 0x01
bcdUSB: 0x0200
bDeviceClass: 0x00 -> This is an Interface Class Defined Device
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x40 = (64) Bytes
idVendor: 0x152D = JMicron Technology Corp.
idProduct: 0x2338
bcdDevice: 0x0100
iManufacturer: 0x01
English (United States) "JMicron"
iProduct: 0x02
English (United States) "USB to ATA/ATAPI bridge"
iSerialNumber: 0x05
English (United States) "7D12004B5001"
bNumConfigurations: 0x01
===>Configuration Descriptor<===
bLength: 0x09
bDescriptorType: 0x02
wTotalLength: 0x0020 -> Validated
bNumInterfaces: 0x01
bConfigurationValue: 0x01
iConfiguration: 0x04
English (United States) "USB Mass Storage"
bmAttributes: 0xC0 -> Bus Powered
MaxPower: 0x01 = 2 mA
===>Interface Descriptor<===
bLength: 0x09
bDescriptorType: 0x04
bInterfaceNumber: 0x00
bAlternateSetting: 0x00
bNumEndpoints: 0x02
bInterfaceClass: 0x08 -> This is a Mass Storage USB Device Interface Class
bInterfaceSubClass: 0x06
bInterfaceProtocol: 0x50
iInterface: 0x06
English (United States) "MSC Bulk-Only Transfer"
bLength: 0x07
bInterval: 0x00
bLength: 0x07
bInterval: 0x00
Any ideas on how I can recover my data? Thanks
Capacity: 0.00 GB
Test Result: PASS
Capacity: 0.00 GB
Test Result: PASS
ConnectionStatus:
Open Pipes: 2
bLength: 0x07
bInterval: 0x00
bLength: 0x07
bInterval: 0x00
bLength: 0x12
bcdUSB: 0x0200
idProduct: 0x2338
bcdDevice: 0x0100
iManufacturer: 0x01
iProduct: 0x02
iSerialNumber: 0x05
bLength: 0x09
bLength: 0x09
bNumEndpoints: 0x02
iInterface: 0x06
bLength: 0x07
bInterval: 0x00
bLength: 0x07
bInterval: 0x00
