Help removing Zalman Z11 plus front panel
johndan102496
139
I got this new case yesterday which is almost completely metric by screws and everything and today I tried removing the front panel to install a DVD drive but I have tried and tried pushing the pin latch things on the top but they are smashed looking and won't come off. I have gotten the 2 bottom ones undone that were round but not the other top 2 on both sides. Any idea's?
You may or not have figured it out by now, but on the bottom of the front panel, you can feel a slot that kind of feels likes it is made for a hand. You turn the case so the front faces up and you pull on the bottom as hard as you can. It should come off.
