Help! Router Question
Enderstream
256
So my friend is looking for a router, Although he needs one that connects directly to the wall socket.
Basically same layout and size of a wifi extender that connects directly to the wall but acts as a router.
Price isnt the main concern at the moment, Just functionality and it has to be small and direct connection to a wall plug, no cables etc.
thankyou for your time
What type of wall plug? Is it for power or for data? What service provider do you have?
If you talking about a router that plugs directly into the wall without a AC/DC converter you not going to find one. Routers tend to be too small to have the power circuits internally.
