HELP! Sound Volume problems with Sony MZ-Nh700
zobin
Hey,
I recently got a Sony Mz-NH700 Hi-MD player (it´s great by the way), but I have a little problem.
When I use SonicStage to transfer the songs it works good, but when i listen to the songs in the MD the sound volume is painfully low. I have to turn it to 28-30 (max) to have a decent sound level.
And the other problem, it´s maybe a related problem, is when i turn on the EQ in the player (doesn´t matter which setting) the sound really get´s annoying.
Not only does the volume get lower than before, but the sound volume goes up and down.
For e.g when you listen to a live recording the sound of the crowd cheering is loud, but then when the band plays it get´s lower. And during to song to, depending om if the drummer plays on the kick or cymbal or anything.
It is really annoying.
How can I fix this? The mp3 and wma´s are ok, it´s not a problem with those it must be something else.
Please help,.
Thanks
lb19984
671
Nice player by the way
Well I have a ipod mini and I had the same problem I just reinstalled the firmware. I'm not sure if thats it but its worth a try.
If its not that you might have to call sony
System Spec's:
Asus P4c800-E 3.2e @3.8ghz
1gb corsair xms pro2-2-2-5 aiw 9800 pro
audigy 2zs klipsch ultra's
74gb raptor wd 2000jb
pioneer 108 pioneer 120s
