G
Guest
Guest
Archived from groups: rec.games.video.arcade (More info?)
If this is the wrong board to ask for help, please inform me of the
correct forum to post to .........
I picked up a free Space Encounters cabinet which I would like to fix
in an effort to learn how to "fix a machine". Are there any websites
which detail how to approach fixing an arcade cabinet.
The game supposedly booted up and could be heard but the monitor was
garbled. I looked around the web and I would assume the problem is
due to bad RAM, which I understand is very common on such machines.
However, when I got home with the cabinet, the monitor no longer comes
up at all, so I am not quite sure what happened.
I was directed to the following Space Encounters manual .....
http://www.arcadedocs.com/vidmanuals/S/SpaceEncounters.pdf
.... and was told how to test whether the power supply board was
producing the required 16.5V-Ac, 9.0V-Ac, 9.0-Ac, 16.5V-Ac and 5V-Dc,
12V-Dc, -5V-Dc values. Based on the pinouts and color coding of the
wires in the PDF file, I did verify the power supply was producing
these values.
I have no idea what to try next...... :>(
Keep in mind, I pulled out the switch which is mounted on the back
door wooden panel, so this should always allow current to flow through
while I am working on it. I also turned on the machine by switching
on the switch mounted on top of the machine. When I do this I heard a
"hummmmm" in the machine, so I know something is "on" ... probably the
monitor warming up. I then verified 120V were going to both of these
switches as well as the monitor molex plug. Also, I have no coin door
and there is no slam switch which I can see. The previous owner told
me the machine turned on and the monitor was garbled even though there
was no coin door, so I do not believe the slam switch stuff applies to
my cabinet. Now, however, the monitor no longer comes up ...... so I
am trying to solve this problem first .. of course.
Anyway, I have no idea what to test/try next. I am not good at
electronics, but consider myself somewhat smart so hopefully I will be
able to catch on to what people recommend me do...... My work has a
plotter so I was able to print out big circuit diagrams from the PDF
file I referenced above ... which makes looking at them easier. Of
course, since I have no background in electrical anything, I simply
just look at these diagrams and marvel at all the lines which connect
everything.
Any ideas on what I should test next? If so, please describe what I
should do........ thanks. Hopefully there is a website which will
enligthen me as well ..... however, if someone here would love to take
me on as a pet project ... that would be excellent.
PS: I have a few game logic boards and a couple of main PCB boards
and I think I also have a couple of extra sound boards, so I hope I
have enough "pieces" to try to fix this thing.....
these values.
everything.
