HELP!!! Spilled Coffee On My Laptop
LoveOverClock
79
Guys I accidentally spill my coffee on my laptop, it continues to work.I removed the battery plugged it off and put it upside down...What else can I do? Is it possible to never work again, because the moment I spilled it was working and even battery was wet....Also I have a lot of important things in laptop HDD how can I save them?
If the hard drive is removable and you don't have full disc encryption or anything, I would remove the HDD so as to not damage it (any more than it already is). Plug it into a desktop and grab whatever files you need off of it.
As for the laptop itself, it is hard to gauge damage without looking at it but it's safe to assume the laptop is now unreliable at best and unusable at worst.
Disconnect all power sources/battery
Wipe away any visible moisture
Place in tub of silica packets/clean rice if you dont have any silica
Hope for the best 🙁 Good luck mate!
