[SOLVED] Help to determine the condition of my Motherboard
VoeAllem95
Commendable
Jun 5, 2020
6
This is my first time on building my own PC
And when I set up all of the parts and start to power, theres no sign at all. The fan not working, rgb light not turn on. There's literally no sign of power on
So I decide to unplugged all of the components. My PSU is good, it is working with the tester. But when I connect my PSU to the motherboard, PSU fan not working and theres no sign of power on
After I analyze and see my motherboard, I remember that my stupidity, I screw the MB to the case without standoff. My case have a default standoff attached on some holes but not all the holes have it. And then I look at the metal around the screw hole on MB and it turns brown. Is this can be concluded that my MB already fried and failed? I not yet try to plugged all the components on the MB outside the case as Im afraid I will make more mistakes
This is the spec of my rig
Ryzen5 3500
Msi B450 gaming plus max
Ram team t foce dark z 2x8 3200mhz
Zotac rtx 2060
Seasonic focus gold 550w
Be sure the default standoffs didn´t short the board
Take out the motherboard and run it on a non conducting surface (don´t use the packaging or card box of the motherboard, this can be coated and made of conducting material)
take some pictures of the system and the brown place, upload to imgur.com and post the links
Thank you for your feedback.
I really scared if my mobo damages
This is the pictures of brown places. Its only on the screw holes 2 out of 9. This pictures shows these 2 from front and back
I will try your suggestion and update later
View: https://imgur.com/CuXoiL9
View: https://imgur.com/XvapkPb
View: https://imgur.com/y1n8McN
View: https://imgur.com/kbxoacw
