Hello everyone[/i]
I bought
gigabyte ga-p35-ds4 Motherboard
with
xeon x5460 CPU .
The problem is that this mobo requires 8pin connector for CPU but my PSU only has 1x4pin connector.
Is it safe to use only that 1 4pin connector and connect it to half of 8pin(i think not),or is there any adapter to use to create 8pin connector with enough power to power x5460.
Its TDP is around 120w which scares me away of using one 4pin connector.
I just want to hear Yours solutions about this.
Here is an image that shows 8pin connectorfor my mobo;now, do i need to power only 3,4,7 and 8 pin for cpu to work.And if yes...will it be enough for x5460?
Thank you!
I bought
with
xeon x5460 CPU .
Thank you!
