mozzartusm
Splendid
How much does that particular model cost? Also what does it cool? The CPU only, or other parts also? Im not familiar with that model, my first water system was the Thermaltake Bigwater. Its ok, and for someone that has never used one it is easy to install. The Radiator can go inside or out, and so can the pump if need be. This model only comes with the CPU heatsink, but thats all I really needed anyway. I have tweaked this cooling system every way that I know to and have had some very surprising results. I will probably get laughed at for this comment but here it goes anyway. My case "Thermaltake Shark" has one 120 intake fan on the front and one 120 exhaust fan on the back. Of course there are also the two fans in the PSU. The Radiator and its 120 fan mount in the place of the exhaust fan. Basically the setup doesnt change as far as the case venting goes. My case stays very cool so I decided to try something different. I reversed the rear fan that sits on the radiator so that it pulled cool air into the case. Now this means that I have two fans on each end pulling air into the case and only the PSU to vent the warm air. To my surprise, my CPU temps fell around 7C under full load. That is probably being conservative"The numbers". There isnt much if any noticeable change in temps on the other components or the case temp. I have ran the machine both ways and used my infrared thermometer over hours of testing so I am confident that these temps are correct.
The other thing that will increase performance by decreasing temps is to use a different flow path than the one Thermaltake instructs you to use. Im not sure what other companys suggest for their flow direction, but Thermaltake instructs you to go from the pump - Waterblock"CPU"-Into Radiator-Out Radiator-Back to Pump. This struck me as odd but I set it up as the instructions said. It does fine that way, but if you change the flow direction it will help another 3-5C. Out of Pump-In Radiator-Out Radiator-In Waterblock"CPU"-Out Waterblock-In Pump. This way the the hot water is being cooled just before it hits the Waterblock. Like I said, either way is fine, but after hours of reading the temps with an Infrared thermometer I am convinced that changing the flow direction is best. I think that part of the difference is because the pump itself puts off some heat so this variation takes that out of the equation.
