[SOLVED] Help /w High End PC Build
pwncakes
16
Hello there! I'm thinking of building a new PC! (Could you please let me know your opinion? I'm upgrading from a GTX 970 with i7 -3700 CPU ). The parts are listed below:
CPU: i7-9700K
GPU: MSI RTX 2080 Super 8GB Gaming x Trio
Motherboard: ASUS ROG Strix Z390-F - Gaming
RAM: Corsair Vengeance RGB Pro 32GB DDR4-3000MHz
Cooling: Corsair Hydro Series H100i RGB Platinum
Fans: Corsair LL120 RGB 3 Fan Pack with Lighting Node PRO 120mm
HDD: Western Digital Purple HDD 3TB
SSD: Samsung 860 Evo 2TB
Will my current PSU support the above system? Or I need to get a new one? I have the Corsair RM Series RM750 80Plus Gold. Also any Cool RGB PC Case out there below 150$?
Thanks!
There are several Gigabyte models but generally it doesn't matter once you start overclocking as they all tend to reach similar limits. If you can't decide just get the cheaper.
I see! Gigabyte one seems to be around 40$ less at least in my country. Will think about getting that one instead then, but I think it does not have RGB lightning. Thanks for the help friend! Appreciate it!
