is it better to go sli + dedicated physx or go tri sli?
is sli + dedicated even possible? will it use higher power than tri sli?
my pc specs are intel C2Q 9550 at 3.2ghz / 1800 mhz ocz reaper 4gb / 3 x gtx 260 / psu not yet confirmed
There all working, how hard depends on what you are doing. When I'm just surfing the machine is using 405W of power but if I'm playing Crysis I'm averaging 750W.
