whoa199 Reputable Nov 9, 2014 59 0 4,630 Oct 1, 2015 #1 Hello i would like to upgrade my computer in not sure what items to upgrade. GeForce GTX 750 Ti Intel(R)Core(TM) i5-3330 CPU @3.00GHz 4.00 GB RAM
Solution Archgaull Oct 1, 2015 Ram definitely needs an upgrade to 8GB, but between the GPU and CPU the GPU needs an upgrade more. Also, I'm assuming you have a 64 bit operating system, otherwise more than 4gb of RAM will be useless
Archgaull Admirable Nov 12, 2014 1,873 0 6,460 Oct 1, 2015 Solution #2 Ram definitely needs an upgrade to 8GB, but between the GPU and CPU the GPU needs an upgrade more. Also, I'm assuming you have a 64 bit operating system, otherwise more than 4gb of RAM will be useless Upvote 0 Downvote Solution
geofelt Titan Oct 9, 2006 55,330 4,539 174,240 Oct 1, 2015 #3 What would you like to accomplish? What is your budget? In what way might your current pc not be doing what you want? Upvote 0 Downvote
