Ok, I switched out the RAM, will I have any problems with this, what do we think folks?For gaming dual tower is recommended and you will face this issue with most dual towers. The other alternative is AIO which will increase the budget quite a bit for similar performance.
Instead I would recommend to go for a low profile RAM as originally suggested in my part list. In most instances you wont be able to make out the difference between 3600mhz CL16 and CL18 memory, and it will fit nicely.
PCPartPicker Part List: https://pcpartpicker.com/list/M7W2t7
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor ($199.33 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler ($34.90 @ Amazon)
Motherboard: Gigabyte B550 UD AC ATX AM4 Motherboard ($104.43 @ Amazon)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($47.99 @ Newegg)
Storage: TEAMGROUP MP44 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($68.98 @ Amazon)
Storage: Western Digital WD_BLACK 2 TB 3.5" 7200 RPM Internal Hard Drive ($99.99 @ Dell Technologies)
Video Card: PowerColor Fighter Radeon RX 6750 XT 12 GB Video Card ($299.99 @ Amazon)
Case: Fractal Design Pop Air ATX Mid Tower Case ($49.99 @ B&H)
Power Supply: NZXT C750 (2022) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($79.99 @ Best Buy)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer ($24.49 @ ASUS)
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit ($119.99 @ Amazon)
Total: $1130.07
Generated by PCPartPicker 2024-09-21 21:32 EDT-0400
