help with building gaming pC
Mar 21, 2018
31
What do you guys think about this build?
•Intel core i5-7400 (already bought it)
•GTX 980 4GB as graphics card
•Cryorig h5 CPU cooler
•2x4GB RAM (from whatever company, does it really matter?)
•ADATA SSD 128GB disk
•Seagate 1TB HDD disk
•Corsair - RMx 650W Power supply
•Asus H110M-K DDR4 LGA1151 mATX Motherboard
-Do I need more than 1 fan?
-Also what case would you guys recommend that isn't too pricey and would be suitable with these pc parts?
I'm buying all of the parts off ebay/amazon (so basically used) so my budget isn't too big.
I would recommend having a couple of case fans at least. You could do one 200MM fan in the front and a 140 in the back, or a couple 140s in the front and 1 in the back.
Phanteks makes some fairly inexpensive and quiet fans.
Mar 21, 2018
31
a lot of my friends have similar build and they're happy with it :) besides i dont want to spend too much, i dont expect to play on highest/ultimate settings
Mar 21, 2018
31
Which mobo would you recommend then?
