Question HELP WITH CABLES - Build in progress - Phanteks P500A
Hrsn
Commendable
Jun 15, 2019
36
4
1,535
Hi guys,
Im in the middle of a build with the P500A case
We have plugged in most of the cables
We have purchased a fan controller. - It is the phantek fan controller
The exhaust fan plugs into the fan controller as well as the 3 front fans that come with the case.
We have another cable with 3 pins coming off where the 3 front fans are, saying DRG-FAN however it can't connect to the fan controller.
We also have another cable from the case called MB RGB which we think needs to go into the motherboard's RGB slot.
However where does the RGB FAN connection go that is coming off the 3 fans at the front? im confused
Also, the case only seems to come with a POWER SWITCH cable and no RESTART cable, is that normal? Weird considering there is a button on top to restart
