I need help picking a case. Here's my build so far:
AMD Phenom II X3 720 2.8GHz Socket AM3
BIOSTAR TFORCE TA790GX 128M AM2+/AM2 AMD 790GX
XIGMATEK HDT-S963 92mm Rifle CPU Cooler
Corsair 4 GB (2 x 2 GB) DDR2 800 (PC2 6400)
MSI N250GTS-2D1G-OC GeForce GTS 250 1GB
Western Digital 320GB 7200rpm
OCZ Fatal1ty OCZ550FTY 550W
Pioneer Black 20X DVD±R
I was originally looking at the Antec 300 case, but the size might be a bit too big. I need the height to be around 16-17 inches. What do you think of this case? http://www.newegg.com/Product/Product.aspx?Item=N82E16811147114
Will that fit all of my components? What I'm most worried about is the CPU cooler and the power supply (I've heard that Fatal1ty is kinda large). The video card is smaller than most nowadays... I think less than 10 inches long. Will that case do well with cooling?
Thanks.
P.S. This is the other case I was considering: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147057
Thanks.
