Help with choosing a case?
Broken3D
25
i have a gaming pc which takes too much space. i need to buy a smaller case than it already has but i dont know which ones the system will/wont fit into.
this is pc and the case i have http://m.ebay.co.uk/itm/191025096255?cmd=VIDESC&gxo=true
there is plenty of free space in the case sideways... all if those specs plus 1x pci wireless adaptor and 1x pcie graphics card is all i have. on that same mobo.
so i am looking for a case under 30/40 quid and with a 500psu.
size is more important than style for me. the smaller the better !
some suggestions please!
what abiut this? http://m.dabs.com/products/best-value-mj-705b-micro-atx-with-usb3-0---500w-12cm-psu-9C44.html?src=3#reviews
Case is subjective but don't get a case that already has a power supply unless it is the EVGA Hadron. Most of the time these power supply are generic brands and can prone to fail which can cause damage to the hardware in your pc.
Motherboard should be considered when deciding a case. The smallest your case can be is a micro atx unless you change your motherboard to a mini-ITX
I would get a new power supply that is a better quailty :XFX 550W
http://uk.pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
