help with cpu fan speed
blindrider
hey how do i change CPU fan speed cuz mine is running way low it is a athon 3700 AMD and it is running at like 1700 rpms or less my mobo is the asus A8n and my fansisstillrunning way low plz help if you have anymore ideas relpy
it depends on if your mobo has a fan speed monitoring function or if the fan has a speed controller. what mobo do you have?? first try the program speedfan
it's running at low speed cause windows tells it to--not much program running probably...
