Hello, so this is not an intimidate issue, but one I discovered when putting in my sound card today.
The PCIE slot is covered by the bottom half of the GPU, so if I were to add a second GPU, I would have to remove the sound card. Probably should have gone over the access points myself but as it was my first build I looked it over at PC Part Picker and let it see if it was a fit.
MOBO: Gigabyte GA-F2A88XM-D3H
GPU: MSI Radeon R7 370 4GB
Sound Card: Asus Xonar DX 24-bit 192 KHz
Note, I'd probably have to get a new MOBO when upgrading the GPU anyway's as I'd probably need a better CPU by then. Just checking incase I'm just missing something for this type of setup and trying to improve my PC building knowhow.
Cheers
Cheers
