Hi there, I've seen a few threads similar to what I'm going to ask but I just want to confirm everything especially for my hardware.
I'm going to be getting the Phanteks P500a case and want to add 3 more Phanteks SK 120mm PWM DRGB fans.
2 on the top, 1 at rear.
Case: https://www.phanteks.com/Eclipse-P500A-DRGB.html
Additional Fans: https://www.pbtech.co.nz/product/FANPHA03120/Phanteks-SK-120mm-PWM-Fan-Digital-RGB-3-pack-Black
I have a Gigabyte B450 Gaming X motherboard:
https://www.pbtech.co.nz/product/MBDGBM33406/Gigabyte-B450-Gaming-X-ATX-Motherboard-For-AMD-Ryz
It has these connections for fans (leaving out CPU ones):
SYS_FAN1 /2 /3 (4 pin)
LED_C (4 pin)
("max power rating 2A (12V)")
D_LED1 /2 (3 pin)
("max power rating 2A (5V)")
This is what I'm planning to do from what I've heard (please let me know if I'm right or wrong).
POWER:
The 3 stock front fans on the case are apparently not PWM so they are 3 pin, but that's fine, I can use a splitter and plug them into one of the 4 pin SYS_FAN headers right?
The other 3 fans are PWM 4 pin so I can just get a splitter and then plug into one of the other SYS_FAN headers?
RGB: (this is what's been bugging me)
So I want to control all my fans via software, my motherboard supports RGB Fusion 2.0.
For front 3 stock fans, can I just use a splitter that goes to one of the D_LED (5V)headers?
And for the other 3 fans get another splitter that goes to the other D_LED header?
I'm just worried about the voltage stuff because the D_LED headers say 5V but then the additional 120mm ones I'm gonna buy say "rated voltage 12V" or something.
But yeah it's mainly just all the voltage and rgb stuff I'm worried about, it'd be great to get some help.
Cheers.
LED_C (4 pin)
D_LED1 /2 (3 pin)
POWER:
Cheers.
