Jun 21, 2019
6
I have an AMD Ryzen 1600 and GTX 1060 6gb. Recently, for an unknown reason, whenever I turn on the PC, after a few minutes of doing anything or even nothing, it starts acting up. Everything freezes for a bit, as in the image stays still for 0.1 ish seconds, not sure exact, but it's for a slight time. I exit the game and do normal things and it persists, even when I dont open Overwatch and just watch Netflix on the PC, it starts doing the same thing after a while. I tried updating drivers and whatnot and I keep getting 2 main BSOD errors; PAGE_FAULT_IN_NONPAGED_AREA and DRIVER_POWER_STATE_FAILURE. Anyone have any Ideas for how to.fox this or troubleshoot? Thank you!
full system spec? include make and model of the psu
check cpu/gpu temp and usage during the game?
check ram/ssd/hdd usage during the game?
Ryzen 1600; GTX 1060 6gb; 16gb Ballistix 2400 MgHz Ram; 4 Drives, Main is 256gb M.2 SSD; PSU - Rosewill https://www.amazon.com/ROSEWILL-Computer-Warranty-LEPTON-500/dp/B0784B7ZWR
How do I check those during the game? All I can do is monitor the FPS and it goes down every now and then, but it isn't the gpu unable to keep up. I OC my Monitor to 75hz, but when i set it back to 60, the same things happen, even 30 fps gives me those drops
Here is an example of what would happen continuously, even out of the game. A frame would freeze for a fraction of a second and audio also goes with it. It isn't my computer being too slow because like I said, I set it to 60fps and even 30 and the same ting here was happening Giphy Image (You have to click on the image for it to run apparently)
View: https://gph.is/g/ZOlL06j
