G Guest Guest Jul 18, 2010 #1 Hello,I lost the windowxp games where can i find to get in my computer to install it? thanks clare
CantankerousV Distinguished Jul 17, 2010 14 0 18,520 Jul 18, 2010 #2 Do you have you original XP cd? Upvote 0 Downvote
tigsounds Splendid May 29, 2010 3,922 1 23,460 Jul 19, 2010 #3 Hello,I lost the windowxp games where can i find to get in my computer to install it? thanks clare Click to expand... As implied above, you will need your XP CD. Go to: Start > Settings > Control Panel > Add or Remove Programs. After the list fills, click the button on the left edge of the box indicating "Add/Remove Windows Components." The first choice showing is "Accessories and Utilities" Click it and then click "Details" Notice the Games are shown there. Check the games and click Ok. Click Next. It will install as needed and finish. Upvote 0 Downvote
