Recently I have purchased two new 460gtx both cards are great they run really quiet and cool and in certain games get excellent frames. However when testing them out with Crysis and BF2BC I get absolutely low fps on low settings (everything set low in the game options. About 15fps if am lucky in Crysis and anywhere from 20-25fps in BF2BC from what I can tell from doing a bit of research on the internet is that I should be getting a lot more. Was thinking that my CPU is bottle necking my GPUs.
1680 x 1050
EVGA 460 GTX 768MB x2
4 Gigs of Ram
AMD Athlon 64 X2 Dual Core 5200+
Windows 7 Ultimate 64bit
Up to date drivers
Checked out settings in Nvidia Control panel and SLi is enabled, everything else is hooked correctly with both cards. However I plan on upgrading things over time, and I never bothered to order a new PSU currently using a 700W PSU and both cards are getting enough voltage through the EVGA OC Scanner so not sure if that's the problem. Can't think of any other things off the top of my head to include if you need more info let me know.
Currently running two monitors but get the same FPS with them together or just using one. Any help would be much appreciated!!
Thanks.
1680 x 1050
4 Gigs of Ram
Up to date drivers
Thanks.
