Help with M.2 wireless AC card installation.
kedgington
7
Hello all,
I'm building a new desktop PC and I'm going to use a wireless AC card in the M.2 form factor (NGFF). However, I can't seem to find any information regarding antennas for this form factor when used in a PC tower application.
So does anyone know where I can find an antenna for an M.2 wireless AC card that will be used in a full-sized tower case? Do I use a USB solution? The card has the two small jacks that laptop antennas plug into. The card is an Intel 7260NGW.
Thanks in advance!
You'll need these types of cables regardless, but there are a number of choices for antennae. :
These are the longest U.FL to RP-SMA (male) cables I could find - most of them are 6"-7" long: http://www.amazon.com/Super-Power-Supply%C2%AE-Wireless-WN2500RP/dp/B00DIHLOYS/ref=sr_1_17?s=electronics&ie=UTF8&qid=1424110262&sr=1-17&keywords=u.fl+to+rp-sma
Here is a compatible dual-band antenna: http://www.amazon.com/Alfa-Booster-High-Gain-Screw-On-Antenna/dp/B003ZWPRUI/ref=pd_sim_e_7?ie=UTF8&refRID=1R07Z10N21PHHRD58MP5
You're going to want something like the antennae linked below, but there are ones like the one that comes with some Asus boards that have the laptop-like mPCIe connector, but have an external antenna that's designed for use with a desktop. I found one a while back for a build but will have to do a little looking to find it again. I'll post it when I do.
http://www.amazon.com/Wi-fi-Antenna-RP-SMA-Antennas-Cables/dp/B00A4I3AGE
Thanks for the help. I managed to find a dual band antenna and cable kit. FYI, the Gigabyte GA-X99-UD4 has an M.2 connector for both a wifi card and a SSD. The GA-X99-UD4 does not come with the wifi card or the cable kit, but the UD5 does. Go figure. Ya learn something every day.
Thanks again volcanoscout. I ended up finding the same products on Amazon that you did.
