I just built my first computer. Now I'm having a problem setting the right timings with my memory. The stuff I got is Patriot extreme performance (This stuff)
The motherboard is Gigabyte 965P-DS3 revision 3.3 with F10 bios.
It's rated for 4-4-4-12 at 2.2V. It defaulted to 5-5-5-16 at 1.8V with no problems and windows installed fine. I ran memtest86+ for a few hours with no errors. I moved up the voltage to set the timings right. It only would post at 2.1 or 2.2 V. At 2.1V It ran for a while. With my overclock of my e6600 to 334x9, it survived 18.5 hours of orthos with no problems and a few hours of memtest86+. 2.1V wasn't completely working though. Windows would completely freeze sometimes and the system wouldn't post half the time, so I increased the voltage and assumed it was fine until I got a BSOD and ran memtest86+ again. I ran it a few times and I got a few hundred errors only on tests 6 and 7. I tried 2.3V and the system wouldn't post. I tried increasing the MCH and FSB voltages but got the same errors.
I tested each ram module individually. I tried each one alone in each slot on the motherboard, and had no errors at 2.2V. Whenever I had both sticks in, in either single or dual channel, I got the same errors in memtest86+ in tests 6 and 7.
Oh, and the memtest errors seem to come from 2 certain ranges, like ~480-520 MB and ~1480-1520MB.
The problem boils down to whenever I set the voltage of the memory to 2.2V with both modules installed I get errors even though its rated for it.
Are these defective modules or some motherboard compatibility problem or something?
Thanks for your help
