G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Hello Group,
I am trying to fix a Missile Command, which wouldn't boot (would just
run the coin counter), and in test mode would give me the 5th high
beep. According to the Manual, that is RAM K4.
Yesterday I replaced the RAM chip (my gosh... I had no idea it would be
THAT difficult! Took me all afternoon) and the problem was solved.
Game booted, and ran for about 5 or 10 minutes while I adjusted the
monitor (up to this point, I didn't even know if the monitor worked at
all - so I was happy).
Then it locked up with a white screen. I ran Test mode again and now I
am getting the 8th RAM error.
Now before I try replacing another RAM, which I know will take me
hours... is it likely, or possible, that my botched K4 RAM job is
causing this 8th RAM error? Or, is it possible something else is
causing these RAM's to fail (such as a power supply problem?)
Everything on the P/S tested fine, 5V was a hair low but I adjusted it
up slightly with the pot.
Any help is appreciated. I will try just replacing the 8th RAM if
nothing else, but I thought someone might have more insight into this
problem.
Thanks in advance,
Wade
wadelanham at hotmail dot com
Hello Group,
problem.
Thanks in advance,
Wade
