help with my C2Q6600
RampageF84
17
hi guys i have a little pro with my oc i never cant stable my oc this is my spec
C2Q 6600 3.6Ghz 1.4V (400X9)
RAMPAGE FORMULA X48
NB-1.55V
SB-AUTO
SB2-AUTO
FBS TERM-1.5V
MEMOS 4GIG H=G.SKILL 1066GHZ 2.3V AT 1066GHZ (5,5,5,15)
ALL SPECTRUM -OFF
ALL CPU FUNTION-OFF
I use prime95 and i see error msg somethime my pc restard and i have a blue msg please help me y want have my pc stable thank
I think you need more than 1.4 v to be stable at 3.6. that is true at least in my case. i would reduce the cpu frequency first. then, push the fsb with 8 multiplier. Start with 3.2 and leave vcore as it is. You should get it stable. If not up the vcore a little more and set it at 3.3. you can go up to 1.5 v , and keep it below 70C during prime test. if you can get that stable at 3.3 or 3.4 , live with that. the performance difference between 3.3 and 3.6 is not much compared to the voltage you use.
i use 1.5v -1.55v and nothing the same error in the prime95 somethime i use at 3.0GHZ and the same error i dont know what is
I use the default voltage for the chipset. I use 9 multiplier and i am at 3.3. my board support 1333 fsb and it is running at 1468. It is stable so i do not increase the nb voltage.
If you need, just increase nb voltage a little bit. Make sure you lock the pci express and memory. you need to underclock your ram. leave the mem voltage as it is.
check your temperature as well. sometimes your oc fails if you are overheating. keep it cool. disable stuff like eist, cie. i donot know how your board call them. google it.
can you show me pics of cpuz, coretemp, and bios settings. then i can help you better.
