Question Help with my cooling fans... cpu's going crazy!
Aug 12, 2020
45
Hi there, I'm new at this
My system's idle temperature is 45-50C and while gaming it get's from 61 to 70C(sometimes 72). my idle temp seems very high considering what I saw in other forums and YouTube videos. So I changed my cpu and system fan speeds from my BIOS as below. Please can anyone suggest me if this is a good setting? systemfan 1 is rear fan and 3 is the front one. Also when I applied this settings my idle temperature is still at 50C on Ryzen master. Considering there are no noise issues. I want to make it cool and power efficient as much as possible.
CPU fan:
45C ~ 6000RPM (45%)
60C ~ 8000RPM (60%)
70C ~ 11000RPM (80%)
80C ~ 13500RPM (100%)
SYSFAN1(rear fan):
45C ~ 8000RPM
61C ~ 10500RPM
70C ~ 12000RPM
80C ~ 13500RPM(100%)
SYSFAN2 (front fan):
56C ~ 6000RPM
65C ~ 10500RPM
73C ~ 12000RPM
84C ~ 13500RPM(100%)
My specs:
Ryzen 3100
16GB 3000mhz RAM
MSI B450 TOMAHAWK MAX
GTX 750 TI
Also please advice me on how to optimize gpu fans on MSI afterburner.
Thanks.
Aug 12, 2020
45
1200 Rpm for a lot of fans is max. Set your min speed a few hundred rpm higher than it is now. Does it help?
I see Yes. but actually the graph starts with 0 1500 3000 upto 13500. And when i set it to like 6000 it was running at 1300. what's that about??
