Help with my pc problems
Chelston Low
Commendable
May 28, 2016
21
Sometimes while gaming, the game freezes. Only way to solve it is to end the process via task manager. However, when i launch task manager, my mouse cursor cannot be found and i can only navigate using the tab button to switch between processes to end the game. The game i play is mainly counter strike : global offensive.
The pc is use is DELL xps 8700 running windows 8.1. Any idea what can cause this? A virus scan on Vipre did not find any viruses or malware.
*Had to resort to asking help on a forum as i cant find a solution online*
Check your Temps using HWmonitor in game.
on old hardware, or even after 2-3 years its good to change the thermal paste on the CPU, GPU and thermal pads/compund on the Northbridge of the motherboard.
Also your fans may be broken or dusty , its good to clean them also.
Alright i will definitely try that as i have not done so since my computer was bought. Which was 2 years plus ago. May i know what should the optimum core temperature while resting and while gaming?
