Help with Netscape Browser
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I installed the Netscape Browser, after the instalation, I click in the icon
and does not open. I used this browser before, but because I had the PC
infected with viruses, I was able to re-istall Windows XP, however when
installing, my hard drive was formated to NTSF when it was on FAT 32. Does
that mistake is the reason I cannot open the Netscape Browser?
And when did Microsoft 'build' Netscape.
If you want their help with their product look on their support forum.
If you can't find one, maybe you should revert to Microsoft Internet
Explorer: help and support avcailable in one of these forums.
"Carol Alfonso" <Carol Alfonso@discussions.microsoft.com> wrote in message
news:C56A8287-83F3-4DF5-91F3-7DB7C5E57B47@microsoft.com...
>icon
> Does
Uninstall Netscape, reboot, and get Mozilla Firefox 1.01. MUCH better than
Netscape.
I suggest (a) making sure that your PC has no scumware, and (b)
un-installing and re-installing Netscape.
Caution: AOL updates Netscape seldom, so it often has unfixed bugs and
security issues which were fixed long before in Netscape's popular
siblings, Mozilla and Firefox. You may want to consider using another
browser.
No the file system is handled by XP. Try the latest Mozilla. Look and
feel is the same but it is more up to date. Be sure you get an install
the latest Java as well.
John
