Help with new pc build!!!
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi, I would like to upgrade my brother's old celery 300A computer, so
I'm thinking a Pent 4 mobo and chip and possible memory and case. I
can put it together but I'm not good with specifications.
Please recommend the above items that work together well!!!
I will be using his hard drives, cd roms, sb live card, video card,
and other items from his current celery 300A computer, I basically
want to get him going faster. He plays a few games but is mostly
learning to use the Internet and writing, drawing on the computer.
Thanks for everyone's help with this!!!
If that's what you want, then these items should work for you:
ANTEC Life Style Series Black Case With 380W Power Supply, Model "SONATA"
Case Type: Mid Tower
Color: Piano Black
Material: 0.8mm SECC Steel
Drive Bays: 5.25" x 3/0, 3.5" x 2/4 (external/internal)
Expansion Slots: 7
Front Ports: 2xUSB & 1xIEEE1394 & Audio
Power Supply: 380W
Cooling System: 1 x 120mm Fans Rear
Mainboard Compatibility: Standard ATX
Dimensions: 16.75"x18.25"x8.13"
$96.00
ASUS "P4P800-E Deluxe" i865PE Chipset Motherboard for Intel Socket 478 CPU
-RETAIL
Supported CPU: Intel Pentium 4/Celeron Processor (Prescott Ready)
Chipset: Intel 865PE + ICH5R
FSB: 800/533/400MHz
RAM: 4x DIMM for Dual Channel DDR400 Max 4GB
IDE: 2x UDMA 100 by ICH5R, 1x UDMA 133 by Promise 20378
Slots: 1x AGP 8X, 5x PCI, 1x ASUS Wi-Fi
Ports: 2xPS/2,2xCOM(Rear 1),1xLPT,1xLAN,8xUSB2.0(Rear 4),2xIEEE1394(Rear
1),1xGAME,Audio Ports
Onboard Audio: ALC850 8-CH
Onboard LAN: Marvell 88E8001 GbE
Onboard 1394: VT6307
Onboard SATA/RAID: 2x SATA RAID 0/1 by ICH5R, 2x SATA RAID 0/1/0+1 by
Promise 20378
Form Factor: ATX
$113.00
Intel Pentium 4/ 3.2E GHz 800MHz FSB, 1MB L2 Cache, Hyper Threading
Technology - Retail
Model: Intel Pentium 4 w/ Hyper Threading Technology
Core: Prescott
Operating Frequency: 3.2GHz
FSB: 800MHz
Cache: L1/12K+16K; L2/1MB
Voltage: 1.25V-1.525V
Process: 0.09Micron
Socket: Socket 478
Multimedia Instruction: MMX, SSE, SSE2, SSE3
Warranty: 3-year MFG
Packaging: Retail(with Heatsink and Fan)
$218.00
Corsair XMS Extreme Memory Speed Series, (Twin Pack) 184 Pin 1GB(512MBx2)
DDR PC-3200 - Retail
Manufacturer: Corsair
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2-3-3-6 T1
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Special Features: With Platinum Heat Spreader
Warranty: Lifetime
$193.50
All items are from www.newegg.com
Registered Linux user #378193
You may have luck if you buy a motherboard/CPU combo with the RAM included.
then u know that evry thing will work together. www.mwave.com makes this
easy to do. www.allstarshop.com is a good place to browse for ideas and
info on currently availablr stuff.
"ByteGuy" <byteguy@hotmail.com> wrote in message
news:sadv11lrm5ov1ta92e38iei61erb2d8i8v@4ax.com...
OK, the following from www.newegg.com should work great. I haven't tried
the video card, but have used the other components to build two systems
recently. So I can confirm that the following components will work very
well, even for gaming. I threw a halfway decent video card into the mix,
because I strongly suspect that the video card that is in the celery 300A
system will NOT be compatible with any P4 class mainboard. (if it's AGP or
AGP 2X, it won't work. If it's older AGP4X it still might not work) -Dave
Qty Product Item #
Unit Price
Qty x Price
RAIDMAX Black 10-bay Case, Model "268WBP" -RETAIL
Specifications:
Case Type: Mid-Tower Case
Color: Black
Material: 0.7mm SECC Steel
Drive Bays: 5.25'' x4,3.5''(External) x2,3.5''(Internal) x4
Expansion Slots: 7
Front Ports: USB2.0 x2
Cooling System: 80mm Side Fan x2
Motherboard Compatibility: ATX Form Factor 12" x 10.5" or smaller
Special Features: Attractive Streamline design more info->
N82E16811156018 $28.50 $28.50
EPoX "EP-4PDA3I-3" i865PE Chipset Motherboard For Intel Socket 478
CPU -RETAIL
Specifications:
Supported CPU: Socket 478 Intel Pentium 4 Prescott(HT)/Celeron
processors
Chipset: i865PE + ICH5
FSB: 800/533MHz
RAM: 4x DIMM for Dual Channel DDR 400/333 Max 4GB
Slots: 1x AGP 8X/4X, 5x PCI
Ports: 2x PS/2, 1x LPT, 1x COM, 8x USB2.0(Rear 4), 1x RJ45, 1x SPDIF
out, Audio Ports
IDE: 2x ATA 100 up to 4 Devices by ICH5
SATA/RAID: 2x SATA by ICH5
Onboard Audio: Realtek ALC-65x 6-CH Audio
Onboard LAN: Realtek RTL8100C 100Mb Fast Ethernet
Form Factor: ATX more info-> N82E16813123232 $69.75 $69.75
CHAINTECH nVIDIA GeForce FX5500 Video Card, 256MB DDR, DVI/TV-Out,
8X AGP, Model "SA5500T2" -RETAIL
Specifications:
Chipset/Core Speed: nVIDIA GeForce FX5500/270MHz
Memory/Effective Speed: 256MB DDR/400MHz
BUS: AGP 4x/8x
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video)+DVI connector
Support 3D API: DirectX 9.0, OpenGL 1.4
Cable/Accessories: 1 Cables, Driver CD, Manual
Max Resolution@32bit Color: 2048x1536@85Hz
Retail Box (See pics for details) more info-> N82E16814145076 $79.00
$79.00
Thermaltake Silent PurePower, 420W ATX power supply.UL, CSA, TUV,
CE Approved. Intel Pentium 4 Compliant
Specifications:
Type: ATX
Maximum Power: 420W
PFC: No
Power Good Signal: 100-500ms
Hold-up Time: >16ms at Full Load
Efficiency: >65%
Over Voltage Protection: +5V trip point<+6.8V;+3.3V trip
point<+4.5V;+12V trip point<+15.6V
Overload Protection: Not specified
Input Voltage: 115 VAC / 230VAC
Input Frequency Range: 47-63 Hz
Input Current: 10.0A (Measuring 90-132Vrms);5.0A (Measuring
180-264Vrms)
Output: +3.3V@30A;+5V@40A;-5V@0.3A;+12V@18A;-12V@0.8A;+5VSB@2A
more info-> N82E16817153006 $37.99 $37.99
Intel Pentium 4/ 3.0E GHz 800MHz FSB, 1MB L2 Cache, Hyper
Threading Technology - Retail
Specifications:
Core: Prescott
Operating Frequency: 3.0GHz
FSB: 800MHz
Voltage: 1.25V - 1.525V
Process: 0.09Micron
Socket: Socket 478
more info-> N82E16819116171 $182.00 $182.00
Geil Ultra Series Value Dual Channel 184 Pin 512MB(256MBx2) DDR
PC-3200 w/ Blue Heatspreader - Retail
Specifications:
Manufacturer: Geil
Cas Latency: 2.5 7-4-4
Support Voltage: 2.55V-2.95V
Bandwidth: 3.2GB/s
Organization: two 32M x 64 -Bit
Special Features: Optimized SPD for Dual Channel DDR motherboards
Warranty: Lifetime more info-> N82E16820144309 $69.99 $69.99
Subtotal »
$467.23
M1TE&.#EA`0`!`)'_`/___P```,# P ```"'Y! $```(`+ `````!``$```("
$5 $`.P``
end
M1TE&.#EA2P`.`-4``**BHHN+B]#0T,W-S:NKJ\3#PFMK:U145 T-#965E-[>
MWKN[NEM;6_W^_D)"0N'AX"LK*_GY^>KJZNWM[1H:&CL[.V1D9.;FYB$A(4M+
M2WM[>]34U'%Q<30T-/7U]-G9V82#@Q04%/;V]_/R\K*RLJ>GIXB(AYB8F-32
MT,K*R>CHZ=/3TY"0D,7%Q=_?WWAX>._O[\;(RF!@8-S<W']]?>3DY,"_O_O[
M^];7U["OK_;V]%!04%=75P8&!O___P```"'Y! ``````+ ````!+``X```;_
MP%]O2"P:>[^D<LEL.I_0J++GJUJO6!]"RNUZG=0=SW3+8K=?[A"<GOI #$C+
MYQ&)ZG=10ZL,5;8A#@X02!05@TA)& X5%1T(% 8&%$P5&@PA/Q@=2($.CPB-
MAQA"52H.&2H%`P,M`@(L)R-\0B\^!C\,51(R/P%E(CM(/0%6*PP$#0TDE$D.
M'A<B'#T+$A"Y5@89'U8!0U4-`"$E-@4V"P,D$ 8PM @Y/B4_%B(R!#48&@H'
M)!YH$#M<E*! PP</'K>4I!" H<*.$!%&6)@W(D,)`14P$%"0X1J5*@]V[$"1
MHL6"#R8@X*B")L2%`0+F26@HP<&+#10Z^.B@A((`_Q.^5H0(\8%%(8E*(/BP
M`6#>! <$%E!B,2!3J2HW$E#(\< %BAH94K%,`F$"! \8&)C%$/(%#@P8;C#H
MN0(H@ )#4@#8`B%"AB0]#!1@@ .;!Q<\DK 08/5CE14=(+S@P($'`A)6T!AH
M0"#8@9D.GMXTM),NT `X$6PP^H/""%Q""$@8\( "#P^T'2AF#/C*C10F:- `
M8:)$N[$]3GQ8\ !$A@@&3E+0X$)&@15H6J\(\$-&`QFZ)B91, ."`PL;S#UP
MP&/&@0%[?RQN?&4$`0(P=,Q(T&(/\@F3D& #0C[4<( O9=10P1(42'#"#R$0
M4 4!S?SP# PW🙁!6!RZPD%>!61SX,!<`%]!GA0(==/" #PL@(,-QM$"P!048
M( `!!!AT<B,I2_2 03,4,( )$QUH8Z,0/]K8@XV9T)B(8SZ,4$(R!280@W^T
0M*%E(EL>X>4:6H8I9A `.P``
end
M1TE&.#EA2P`.`-4``-[>WFMK:^3DY(.#@_S\_&)B8N'AX;:VMG5U=;&QL?KZ
M^L7%Q?CX^/+R\EU=7='1T0P,#*BHJ!@8&'!P<9F9F>CHZ%E96?3T]!(2$KJZ
MNO;V]DY.3LK*RGM[>]C8V#X^/J6EI3DY.:&AH28F)M75U3(R,NSL["DI*2TM
M+9R<G-O;VT9&1L_/S_#P\+^_OU%142$A(=;6UE965I65E38V-L+"PJRLK,S,
MS ,#`TE)24%!0?[^_N_O[P8&!O___P```"'Y! ``````+ ````!+``X```;_
MP%]O2.SABL6?<LEL.I_0J'39\UFOGD/ERH5,O^#PL^ICD$ 8V E7X#PN5Z]8
M😉Q#R:0?;.(S^1 2/QEQ4A H.CHC.! T'Q\G/R4E0B<E7B,3$S _*) _-!(P
M'SHT<E%D*CDL$XHK'2PY((11(216`",E#3X*"3TF*C\C'@`E$AP,/@LX"QY#
M/C(I/CLQ'U-D/C4_#@X%%@X0$RH*5J9/)0(=,@P!)0H!(R<0)!<.'SXL(QT5
M.2\$+P$T0/APH4<*`1A&8+AV)4(('P0([/"Q`@&Y<E+032!H`04#$0A00&!1
M@4,''S="V$BPT,.,$ 16##CP(T6#``YZ,.0UH(0/_Q</'C#8\,(/QB@E'NQR
M(>%$`P$>"O2H02%;`A(K,J30^4 $C@H=#B# 455%A(52R!"8@<+'@1L++FRP
MP&,6E!(`1+BP@>$$@0(2($!P@8"%BP(&5++\X2'%CP@V&I0P:. 'VK16"%"X
M)Z#"EKDM[)ZKX `#`!DH%'3X4*J&`S4.*L! 8.*%`V@_`C1H\ -"B@HG0@3"
M7*:G#PT7=FW88-2'.2<A>!3X,0& @UT^?$554H!'"0P+)F8(!(,`30BR?*BP
M1MQ'AA\K2H0HL0("`@VBG?10V'L$A!,HH+ )#'(DI!,,!3@P' XG!(*#! 'Z
=M],T$548T43YV1$%#CAH. H&$B FX>&(&@8!`#L`
end
Hi and Thanks,
I see what youo guys mean!! I should have mentioned what he has in the
first post:
In-win or Antec case, 300 p/s ?
BH6 motherboard
Celery 300 O/ced to 464 MHz
512 Mb Memory
Sound Blaster Live
A Supra 64Mb video card
2 Hard Drives 7200 rpm
10/100 nic card
56K modem
1 CD-R and 1 CD roms
He's BROKE, and I go over to his place and play Links Golf, but I
would like to upgrade his computer a little, as I'm not loaded enough
to get him a new computer. I was thinking an AMD chip and motherboard,
and more memory. He doesn't do the internet alot, nor like RPG games.
What I need is motherboard recommendations!
Thanks again!!!
