help with overclocking
pingu12
40
I am still trying to get my head round this whole overclocking buisness, so i have read loads of these 'noobs guides to overlcoking' and so on, but i am still a little confused. I am currently running a Q6600 @ 2.4GHz (stock) cooled by a Arctic Freezer 7 Pro, it usually idles at around 22-25C, i am using Corsair XMS2 6400 @800MHz (stock). I would liek to overclock my CPU to around 2.8-3.0GHz depending on the temps i am getting. Now i am confused about wether to use a Higher FSB with a lower multipier or the othere way around. (7x400 = 2.8) or (9x311 = 2.8), also i have read about using a 1:1 ratio and is it worth using this ratio or does it not rly matter. If i am being a complete noob or totally missing the plot then plz tell me! also if u need an more information then plz just ask :)
if my system is stable after that should i try and lower the vcore so that temps and power consumption are at a minimum for that clock?
1.35V is the top end of the stock voltage scale.
It is the best place to start for this minor overclock.
If you leave the voltage settings on auto, you can never be sure if the BIOS is dumping 1.1V or 1.5V into it.
It will not hurt to leave it there or even a little higher.
I personally would drop it one notch at a time and test at each step.
Once you start getting errors, raise it two notches and you should be stable for a good long time.
