Question Help with PC Upgrade
rLilLoki
Commendable
May 5, 2017
4
I currently have an i7 4770, 16GB DDR3 and a 1060 6gb
I want to be able to stream with a consistent fps above 144 since i have an 144hz monitor which currently, my pc does not do. My CPU is also regularly at 100% and my pc also decides to slow down or do some glitchy things sometimes.
I was recommended a ryzen 7 2700 + 16gb ddr4 and i was wondering if this would help me with my issues.
My budget is around 200-300 GBP
Thanks in advance.
You're better off building a system meant for gaming while your current system will handle the streaming duties. You're also looking at a new motherboard to pair the processor and DDR4 ram.
List your current specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
I7 4770
MSI h81m-e33
Hyperx 16gb 1333
1tb WD Blue
128gb Adata SSD
GTX 1060 6GB
Corsair 500W
The Ryzen 7 2700 + a new motherboard + the 16gb ddr4 should equal to 300ish GBP
