Hi,
First post here so sorry if its in the wrong place!
My Current PC (Pre built of the internet) has started to make a lot of noise and was running quite hot, added a few fans (Which it didn't have)
http://www.ebuyer.com/138590-xilence-red-wing-80mm-quiet-fan-3-4pin-connection-xilence80
This worked well and took the temp down to around 32C, But the PSU (Cheap unbranded) in this PC is noisy and doesn't get any better the longer you have it on So i have decided to go for an upgrade, this is what I am looking at
http://www.overclockers.co.uk/showproduct.php?prodid=CA-166-CM&tool=3 (£10 cheaper than Ebuyer as its on promotion)
I would like some advice as to if this would be suitable for my PC, at the same time I am thinking of moving it all into a Antec SLK2650 BQE Solution Series Computer Case as I have one here not going to much use and the current case is a cheap unbranded one with not a lot of space.
- Intel Core I7 870 2.93ghz 8mb Cache (Stock Fan, I dont over-clock)
- Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm x 2
- Optical Drive - 24x DVD Writer
- 8GB (2 x 4GB) DDR3 RAM DDR3 1333 PC10660
- Nvidia Geforce GTS 450 1GB
- Motherboard - Asrock H55M-LE
- Windows 7 64bit Pro / Xp 64bit Pro / Ubuntu
- 1 x 22" Hp L2208w
- 1 x 24" Samsung HD Syncmaster P2450
- 1 x 37" LG HD
Thanks in Advance
- 1 x 22" Hp L2208w
- 1 x 37" LG HD
Thanks in Advance
