Help with purchasing a monitor
The viewing angles and image qualities are very much better in IPS Panel monitors than in TN panel monitors.. But TN monitors have faster response times than any IPS monitors.. Faster response is very important in twitch/fps games. The fastest (with faster response time) IPS panel available is with 5 ms response time whereas fastest TN panel available is 1 ms, which is the best response time ever.. Input lag is one which all monitor display maker doesn't provide in the data sheet. Whatever the...
anon1239
80
What monitor is best for gaming, excluding price? I define best as one that will give me both amazing resolution and good performance for next gen games.
The viewing angles and image qualities are very much better in IPS Panel monitors than in TN panel monitors.. But TN monitors have faster response times than any IPS monitors.. Faster response is very important in twitch/fps games. The fastest (with faster response time) IPS panel available is with 5 ms response time whereas fastest TN panel available is 1 ms, which is the best response time ever.. Input lag is one which all monitor display maker doesn't provide in the data sheet. Whatever the resolution is, the IPS panels always provide better image qualities than TN panel for same resolution..
But the G-Sync monitors always synchronize the GPU's frame render rate with your monitor refresh rates and provide superior smoother game play at all instants than the other monitors.. If you're the kind of guy who always watches movies or play games by sitting right in front of the monitor, TN panel will be your choice... But for watching/viewing the monitors from different angles without color shift, you need a IPS monitor.. I prefer gaming in faster TN panel monitors and whi;le watching movies, connect it to a HDTV.. So, the choice is yours..
However, the best monitors for gaming will be THE G-SYNC MONITORS..
anon1239
80
Thank you very much! I think ill go for the asus rog swift pg278q, 144hz because the gsync feature seems to increase the framerate for more stable playing (i.e. A higher fps version of vsync).
