Hi,
NOTE: I have posted the same problem on the memory forum but i did not get many replies so posting it here in motherboard section too. Sorry.
I recently bought a 4 gb ram stick of 1600 mhz and installed it in my system (core i3, Intel DH55pj MB, 2 gb 1333mhz) which had win ultimate 32 bits. The system successfully booted up and showed 6 gb installed with 3.25 usable.
I tried reinstalling win ultimate 64 bit but the setup would be stuck at win logo right at start. Not knowing what to do i puulled out the 4 gb stick and successuly installed the 64bit version with 2 gb only. My thinking was if the 32 bit picked up the extra ram so should this 64 bit one.
Unfortunately this is not working. When i install the 4 gb stick and boot, win 7 fails to start. It shows me the option of start normally or repair. When i start normally the system restarts. When i try reapair windows loading shows up and then blank screen. When i pull out the 4 gb stick, the system starts successfully albeit it shows 'memomry decreased, press enter to continue' message before starting windows
Intel DH55pj officially only supports 1033 and 1333 mhz ram. Yes i know i'm an idiot but plz read this link before u call me an idiot here. infact call me anything u like just help me plz.
http://www.tomshardware.com/answers/id-2016885/ram-spee...
I have already tried to F8 -> safe mode. but every option i try results in resart when both rams are installed. but when i pull out 4gb ram, syatem srats successfully.
also, i took out the 2gb stick, put in the 4 gb stick but windows won't start. i tried to boot from bootable usb to see if i can install new windows (with only the 4 gb stick inside) but the system hangs up just after loading files section when windows logo shows up.
Please keep in mind that this 4gb stick was put in computer alongwith 2 gb stick when it had 32 bit ultimate win7 . there were no problems then as it had picked the 4 gb stick as weel as the 2 gb stick. I only wanted to install 64 bit so all of it would be used. now i'm stuck with this ram i cant return
BTW, whenever itake out or put in ram this screen briefly shows up with messages like 'table mismatch - updating remote pc assist technology setting new table fingerprint [complete]' . i took a pic of this and copied this text to share here. perhaps this might help.
I can't return the ram as it is showing up fine and working and the shop will not taake it back. i've tried looking inside bios for any option that might help but cant figure anything out.
Your help will be greatly appreciated.
