Hi, so my brother bought parts for his new PC and sent it to a local shop to be built. The guy came back to us with it pretty much fully built, apart from the SSD and HD. He said something to my brother about connecting 2 SATA's and a Molex. For some reason the repair guy couldn't do this as he didn't have the cables.
I have attempted to connect both the HD and SSD, with cables from my old PSU as I figured that might do the trick. However, when connected like this the PC will not boot - fans will spin for a second and then stop. I have connected cables to the PSU (the bit where it says SATA should go) and back into the SSD/HD. Then SATA cables from both drives into the motherboard.
Since the PC will not boot I removed these cables and it will boot just fine. Obviously not ideal since the drives are not connected. Does anyone have suggestions on what to do? I'm not sure if I perhaps have the wrong cables or have plugged things in the wrong way. Would really appreciate any advice, thanks!
Parts:
Parts:
