I am in the process of selecting the hardware for my new PC. I buy a PC mainly for games in 2k resolution. Here is the build that I got:
MOBO: MSI PRO Z790-P WIFI
CPU: Intel Core i7-13700KF OEM
GPU: MSI GeForce RTX 4080 SUPER GAMING X SLIM
AIO: LIAN LI Galahad AIO 360 UNI FAN SL120 Edition
RAM: ADATA XPG Lancer Blade 32GB
SSD: 2000GB M.2 ADATA LEGEND 960 MAX
PSU: DeepCool PX1000G 1000w
The problem is that it recently turned out that intel has problems with i9 and i7 crashes.
This is said to be due to the increased input voltage and incorrect power limits.
This mainly concerns the i9, but problems with the 13700kf are also possible. Here I thought about taking
the Ryzen 7900x, but the problem is in the am5, which is also not going smoothly. Raw bios and a lot of malfunctions.
Maybe I just couldn't find a normal motherboard for it. I do not know here.
Someone advised me to take the i5-13600k, but it is noticeably worse in performance than the above.
It may be worth taking 13700kf and immediately lowering the voltage and power, but there are fears that this will reduce performance of i5. Or I could take a 7900X, but then you will have to suffer from motherboards.
What do you think about this? I note that in my case, all these processors cost the same.
